Some will remember I had (have?) a cold start smoke problem intermittently on my 2.9.
This resulted in the Service action ECU update being carried out (which was not done by the first owner/OPC) before Xmas.
Several starts later, long runs/sloping drive/short runs all is WELL! Early days maybe, but good so far. The AOS I bought is still in its bag.
While at the OPC for the ECU update, I was advised upon collection of the car that there was a coolant weep from the front 'rack' pipes. "About £1300 Sir"
I suggested I would fix it DIY, the severity of the leak of the coolant was not quantified, all I know is the temp gauge is rock steady no matter what, no drips under the car...etc.
Because I have a bit of garage space for the next 2 weeks I thought it was cold enough to endure a good look at the connections to the pipes. Up with the nose and off with the wheels.
The steel connections to the alum pipes are all great! No corrosion, no fluid leaks. I liberally sprayed WD40 all over them to help disperse water and put it all back together and washed the car.
Dissapointing to be told of a problem, DIY parts are £340 for a 'kit' or OPC will charge £1300, but there isn't a problem!
While at the front I checked the nice new A/C rads I fitted in November. I was surprised to find big dry oak leaves in there and about 20 'dings' from stones that have flattened a few fins locally.
I fished the leaves out and I'm buying a set of grills after I've typed this little message.
Having now 'saved' at least £340, spent £190 on the grills and still have garage space, I fancy replacing the exhaust corroded nuts between manifolds and cats, those ones....
Seems it is a game of patience and brute force, any comments?
Finally, went for a drive into Wales yesterday just because I fancied some time from working on the old 911, and found a few spots to use this car as Porsche intended...
Does that engine ever sound good above 6K! I think I'm back in love.
