Frenchy
well after much faffing and fettling my car is up and running after a total non start issue, I suspected flywheel hall sensors, changed them out and no joy, stripped an immoboliser out today and tried again, NO !
Back to basics and numpty here had not got one of the sensor plugs fully home, now purring and tick over seems smoother, just need to sort my cooling fans not kicking in, changed the rad sensor, fans okay when jumped, wiring from sensor to fans fine ?
Anyway if anyone is after flywheel hall sesnsors here you go Bosch 0 261 210 028, originally fitted to BMW 6 cylinders as a cam position sensor, I got mine for £38 each the only difference between the originals is that the lead is slightly longer, Porsche near enough £200 each and ECP £174 for the original part number.
At least I can now pull it out of the garage to but the interior back together.
