2bobjones
Hi All
my 2006 2.7C has the four pot black calipers and 299mm discs.
when I bought car Last year it had brand new Pagid pads and discs on front and looks likes original rear disc and pads (only done 37k when i purchased)
the braking left a lot to be desired and not up to usual ‘more than enough’ Porsche braking I have experienced before..
so after good advise on new pads from you guys fitted Brembo sport hp2000 pads and much sharper response and no fade but still making horrible rumbling sound when hot. Same noise with as with old pads.
Did castle combe this summer and brake fine for 1-2 laps then get hot And rumble and started to shudder/warp a little so took It easy and only braked hard and late to minimise use..
now on road still rumble when hot/heavy use (even braking from motorway + speed down to roundabout) no issues with same braking on My modern Audi work car.
so need to sort out for next year but down want to throw good money after bad so what experience/advice on either:
1. New Brembo front discs or Sebro with the still very fresh brembo sport pads?
2. original Porsche discs and keep same pads
3. Look at upgrading front discs to second hand 987S big red calipers and new Brembo 330mm discs and new standard Brembo pads? Will the S brakes fit/attach? (I have 987s 18s wheels Factory fitted)
4. Fit 987 GT3 brake ducts (only £12 delivered and easy fit with a ramp!)
Ps I could of got a 987S for same money as mine but didn’t want potential engine issues with 3.4 engine.
any advice or experience welcome ??
thanks. the rest of the car drives perfectly.
Matt
Matt
