Hi All,
I have a '97 993 C2 coupe. It doesn't have the 3rd brake light fitted (the one that runs along the top of the rear screen) -although it does have a factory-fitted 'dummy' with no actual light inside. I am thinking of taking the opportunity to add a working 3rd brake light. I first thought about doing this a couple of years ago but came across a couple of issues. Firstly, a new OPC brake light will not fit properly in the 'dummy' housing that is already fitted, so I will need a new housing and have that sprayed. The second issue that I realised when I was previously trying to fit a 3rd brake light is that because my screen is clear along the top where the brake light sits, when the brake light is triggered there is quite a lot of red glare that enters the cabin which is quite distracting to the occupants. These issues put me off the idea a couple of years ago but now I need the rear screen replacing for other reasons, and some paint work doing, and I am thinking that I might revisit the idea. So, my question to anyone with a 993 with a factory-fitted working 3rd brake light is: is there some sort of tint or strip that runs along the top of your rear screen which blocks glare from the light entering the cabin? My local OPC tells me that there is only one rear screen available for the 993 and it is clear along the top of the screen. If there is no strip/tint to block the red glare, do you notice this and is it an issue?
Many thanks in advance,
Andy
Andy
