Help identifying a part please
polar964
Hi Folks,
Could anyone provide a part number for the rubber bridging piece / gator, that connects the hot air duct to the air duct above the cooling fan please.
I have looked on the 964 PET at items 964-211-323-03 and 964-106-403-02 and neither show or identify the rubber gator that hold both flanges together.
Mine has started to degrade so requires replacement.
Hopefully you can help.
Thanks very much
Paul
If you mean the rear fan , I think the issue is it’s not available , I had to replace the whole hot air hard pipe with the upgraded version as it’s all in one pipe now that doesn’t have the rubber connectors .
Thanks for your reply Ian. That's a pain!
Would have thought the PET would still list the part though. Does't the PET exist from when the car was in production?
The rubber 'connector' comes as part of 964-106-403-02. Not sold separately. All as a complete unit @ £60.
Ok, cheers. Might of guessed! Is that a recent price?
I've just typed 964 106 403 02 into google and the photos indeed do show the rubber connector as part of the fan duct.
Cheers, thanks Marcus.
I'll have to order one.
No problem Paul. Type 911 has it in stock I see. Does seem daft that as very much a separate component to the plastic cover it isn't sold on its' own. Unless it's bonded or similar to the plastic cover.
if it’s the one I purchased it Replaced the hard hose with a new soft hose that fits better as I understand it’s also for the 993 . If you buy it from a dealer your will get it cheaper than 911design ... as you get 10% off and the real price not the inflated design911 price
Cheers Ian. I'll be ordering it from Porsche. My local OPC provides discount [;)]
