Afternoon Everyone,
First off apologies as it seems that I have different questions every day!
I have been trying to tidy up and repair the wiring inside the car have been sorting out the stereo. The car has an aftermarket head unit (Kenwood KDC-241) and the original loom has been modified to connect to the Kenwood using an ISO connector. I've checked the cables and they look to be going to the right connections, however the volume from both rear speakers is quite faint and 'tinny'. You can only hear them if you use the fader (on the Kenwood) to only play in the rear as the fronts have a really good volume.
The car has the basic audio system (4 speakers) and I think it probably had the centre console fader switch originally. This isn't there now, however from the sound it almost seems that the fader is still there but fading to mostly front despite the head unit, if that makes sense.
The rear speakers do work so the cables to them are ok, but there is something getting in the way of the signal to them. Could there be an amp somewhere that is either broken or not being powered ? Where would I find that (the line diagrams in the manual don't show anything).
I also wondered if the Kenwood had the power to drive the rear speakers, but on paper it looks like it does - they look like the OEM rear speakers - are they 8 Ohms ?
Appreciate any advice !
Andy
Andy
