Clutch pedal buried in the carpet
Vlaanderen_1
Hi All
Put my car in the garage a few nights ago and as usual left it in first gear with handbrake off.
Came to the car this morning and the clutch was fully depressed, couldnt select reverse. Put my foot behind it and popped it out and its now working fine.
The clutch is a few thousand miles old(record of it being fitted by last owner)
Any thoughts? Seems odd but seems fine now.
You will have a fluid leak,
check the the carpet at the top of the pedal where the push rod goes through the firewall
you will need a new master and slave cylinder, folk get the brake fluid changed but never change the clutch fluid, it’s a seperate system from the brakes on a RHD so the fluid absorbs loads of water and rots the cylinders from the inside out
You could try bleeding the system 1st & forcing a lot of new fluid through virtually replacing the master cylinder contents.
Master cylinder for a 924S cost me £ 75 last time I bought from ECP-about 2 yrs ago-slave cylinders seem to last longer
If anyone wants to pop along we are doing a Starbucks and cars at south Mimms services
10:30 - 12 ish
all welcome
