987,2 vs 981 gearing
- Thread starter legin
I don't have the exact gearbox and final drive ratios to hand but I wouldn't expect there to be much difference between a 987.2 and 981. They both use the same DFI engine, although there might be a slight difference in the tune, so expect a very similar in-gear performance.
In other words, don't expect the 987.2 to have significantly shorter gearing, although it might be slightly shorter than that for your ex-Spyder.
but the 981 has larger over all wheel/tyre size and revs higher.
so that = longer gearing, very noticeable imo if still a bit long.
peak in the 981 in 2nd was what about 84mph, in the 987 it's 77 or lower could be 74 I forget !.
as one changes gear below ultimate red line I have zero issues with 987.2 cars in manual.
legin
Im sure MX5 is a fine car however the Porsche is as much about the associations I have built up over the years as it is the car so Im stuck with buying a Porsche.
So today things moved on and I have now collected the 987.2 3.4 manual and so far so good. The noise is feast or famine and in this its famine however I do prefer the sonorous induction aka 997 more than the borish bark of the later cars, its an age thing.
Mr Demon, as Im one to never be content is there a modest way to change this. I would like a little more if easily possible. Induction pipe or secondary cat delete , maybe both? Im not minded to invest too much cash in the car but not averse to some heavy diy.
legin said:Thanks for the info both.
manifold mod by gert or a gert modded back box
or just some Cargraphic sports manifolds like on my car ;-)
modded oem manifolds
http://www.carnewal.com/products/987/p87017/987-2-Exchange-Sport-Cats
