pat bryant
Dear All,
Just changed/renewed the air filter in my 2004, 2.7l, 986. I was hoping it might eliminate a reluctance to 'pull' from about 1500rpm when I floor the pedal. I first noticed this oddness when slowing for a 90degree corner, 2nd gear and then hitting the throttle on the way out; much stuttering and bumping. If I ease the power on it is fine but flooring the pedal, in any gear, from below 2000rpm results in the same condition. Otherwise it goes like a demon, no hint of misfire. I know there are limits to the torque you can expect so it may be that I should not drive it like that. Any views?
Pat Bryant
Pat Bryant
