Funeral
- Thread starter Waylander
richardjjs1
Contact HQ and offer your help
Waylander
and I do the same rob
wash it, drive it, fix it, service it, fix others 968’s and repair parts that are NLA, repair the outside temp gauges and all sorts of other bits
but nothing happens on here, no meets, no drive outs, no nothing
i do stuff for nothing, arrange shows and stuff for the 968 Uk forum guys and girls
1. Is it a straight swap?
2. Was the later gearbox improved to eliminate the 944's chatter in neutral...story goes that early days Porsche fixed it under warranty, but it was so common that eventually they stopped!
blade7
Well-known member
Waylander said:The DMF in the 968 was used to quiet down the drive train but I guess it would be a fairly easy swap
But you would need the change linkage as it's different on the 968, plus a 6 speed gear knob
Fairly sure the 968 torque tube is different to the 944 part, and the speedo trigger. Not sure if 6th gear is much different to 5th on a 944. I've never noticed transmission chatter on my 944 either.
