oil usage
Jim300186
Hi all, new to the forum just bought a 991 gen 2 c4s. When i drive it till its warm then switch it off, and leave it for a few hours then restart I'm getting big clouds of smoke from the exhaust. Is this a normal 911 trait, or should i be taking it back to the dealer? Also noticed in my garage, on the floor and against the units there is an obvious oil spray coming from the exhaust. Guessing the dealer should be fixing this? Or is this a common thing with the 991 gen 2?
Jim,
A small amount of smoke on start-up is quite common with the flat-6 engines but if you're getting an excessive amount of oil spray from the exhaust then I'd definitely go back to the dealer ASAP for further investigation. It sounds as though there could be a problem with one of the turbochargers.
