Waylander said:
it was just LM grease at a guess, nothing to special
Most plastics are not affected by normal grease, and you have some metal to metal in there as well
The grease in the ones I took out & opened was just a yellow LM type grease -looked to be more to stop rusting internally than lubricate particularly as nylon running with metal is self lubricating-some grease was probably intended to lubricate the plain bearings.
I used some open gear aerosol spray I had acquired for free some time ago containing molyslip-it's great stuff-works a treat on my garage door rollers.
Great thanks I'll crack on and rebuild it.
