Air oil separator replacement 996 c4s
Your biggest problem is access
Have you bought 101 Projects for you Porsche Carrera its a must - covers this .
you need a new hose clamp as well
If I remember the problem is getting at the clips at the bottom of the separator
Reasonably easy on the Boxster but not so easy on a 996
£57.30 + VAT (Less Porsche club discount)
Just had it done on my 996. Porsche part £73 + VAT, probably cheaper non-branded. Labour is your potential issue the AOS being situated on top of the engine at the front nearside. My indy wished he'd lowered the engine and with 107K miles and 16 years of use the retaining bolts were fairly well er.... established.
Where is this and what is the price per hour
Don't even think about doing it yourself at 3/4 hour labour
Good luck
rodneyhynejones said:
Thanks. So I gathered. I've been quoted 3/4 hrs labour
Just got hold of a copy - really good, thanks.
Where did you get that quote as PC Colchester quoted £80.08 + VAT?
I changed mine last year whilst I had the engine out. You should get better access with the engine supported and lowered. I would advise checking the two flexi pipes as well.
It is a tricky job with the snap clip and bellows at the base of the AOS. I also had problems getting the upper connector free from the block - the o-seal seemed to have welded itself, as it should just pull off.
On the plus my engine feels great and idles smoothly.
