craiginuk
Hi all,
Am replacing the thermofan switch so need to drain some coolant (about 2litres I think) from the radiator. What antifreeze should I be topping up with. I heard the 944 needs something special due to alluminium etc.
Also, is there anything I need to watch out for with bleeding? Front of car is on axle stands so I was planning to crack open top air bleed screw and fill till coolant come out of bleed bolt. Do I need to run the car in this position too? (not draining the block)
Thanks in advance
Craig
Thanks in advance
Craig
