jwindwood
Guys
Still trying to sort out the in/out movement of the steering column in my early 944.
Have checked that the steering wheel and underdash column bolts are tight, and the UJs under the bonnet aren't loose, it's just that the column moves fore and aft complete with column switches unless the steering lock is on.-I can't figure out why!
Looking at the PET, the steering column is listed as having a "Support ring" and a "clamping sleeve" at the top behind the wheel. Question-what are these like? I know about the plastic spacer behind the wheel (Which is there) but which of the two listed above is this, and what does the other one look like?
Anyone ever stripped a column down before?
Thanks guys.
Thanks guys.
