First gear - clonk!
PaulHere
Pulled out of the drive today, selected first and clonk!
Of course the Porsche "break down in a safe spot" technology kicked in and I was able to pull up to the kerb outside my house before it stalled!
Oh poo I thought, clutch cable has snapped.
But upon closer examination I found the cable intact, and indeed it still lifts the clutch arm - only trouble is this means more trouble than a cable change...
JZ think it may be a broken clutch actuation fork inside the bellhousing.
So car is off the road for a few days till they can take a look [&:]
Think positive Paul, it could just be that the clamp bolt on the lever has come loose and the arm has slipped around on the splines. On my first 924, the release bearing broke up in about 1990, making the clutch so stiff. that it ate two cables in a year, before I was able to afford to remove the box and replace it properly. Even with all that load, the release fork never gave up the ghost. Keep your fingers crossed
