Terry is it? The bump stops play an important role when the headlamp are raised. In fact they are not bump stops at all but travel limits to allow the headlamp to be adjusted to be flush with the bodywork when closed and reach a preset angle when raised so that they can be aimed correctly. If you look closely at the mechanism you will see a hefty coil spring. When the stop touches the bodywork the spring coils slightly to allow for manufacturing tolerances, otherwise the mechanism could strain as it tries to reach the micro-switch. I'll tell you this about oil/cloth mesh filters from my own experience. Claims for their power gains are suspect, I had a BMC 156 in my 911 turbo and have reverted to the standard paper filter, and the car is faster, amd 3mpg more economical. I appreciate that you need to flow more air. but I would try to engineer a better solution, and remember that the std air filter draws cold air in from the wing, and any underbonnet filter must by necessity draw in ambient air from under the bonnet which has to be warmer, thereby reducing the advantage.
