996 c4s gearbox needed!
Mattcastro83
So driving along at 60mph, without warning the gearbox locked up and sheered off at the propshaft, long story short I'm after a 996.2 6 speed manual gearbox for a 4wd., amongst quite a few other parts that were damaged as the propshaft failed in the transmission tunnel. Any help/advice would be greatly received to avoid the eye watering bill I've been quoted using new parts.
Try salvage sales, such as Copart UK, where you buy a complete salvage car take the bits you want and sell on the remains after.
Thinking a 996 C4 use same gearbox and transmission components as C4S, and looks like Copart currently have a 2003 996 C4 (6 speed manual / 2 axle drive) located in Reading.
Hope this helps
Thanks for the tip, I had a look before at Copart but will revisit. I have searched the Porsche breakers but will email all directly this weekend, hopefully something will come up, its too good a car to break.
The only carrera 4 i can see on Copart is a tiptronic. I have found a 2nd rear housing so I will see if I can get it rebuilt at a reasonable cost, most other damaged parts are available 2nd hand so hopefully all is not lost...
