996 C4 - Front Coffin Arm Removal
penkhullwolf
Hi all,
Tried to remove my front coffin arm today and it doesn't seem to be budging at the wheel carrier end, does it get rusted in / two metals reacting?
Seen a youtube video where someone had a similar issue.
Tried spraying some plus gas into it.
Just wondered if anyone had any hints/tips/ things to try?
I got a ball joint separator but can't get the top of it above the nuts screw thread part for some reason.
Haven't tried a pickle fork yet though.
Any advice
cheers
mark
Is the joint splitter this type? I don't think it is corrosion, but they are hard to split at the best of times. Once the splitter is good and tight, try a deft blow with a hammer on the side of the coffin arm near the joint. The shock normally frees the joint.
thanks richard, yes, looks the same as that image. I gave it a big bash with a lump hammer on the side and I think that released it. cheers, i owe you a beer :0)
All nuts/bolts not moved since 1999 by the looks of it.
One side done, onto other side now. Hopefully that will be quicker now i've learnt lessons from first side.
Also decided to replace sway bar and strut braces whilst car is up on axle stands and everything is off/loose
Last bolt in, ready for torque-ing now. feels like that moment when a ship is ready to launch :0)
By the way, when you replaced the sway bar and strut braces, did you notice any significant difference in handling once you test drove the car?
Also decided to replace sway bar and strut braces whilst car is up on axle stands and Drift Boss everything is off/loose
Good luck with the other side, it’s always quicker once you’ve figured out all the hidden tricks on the first one. Great call on doing the sway bar and strut braces while everything’s off; perfect time to get it all sorted in one go.
