Anyone tried the MLP slave cylinder?
jonathan.harris
Hi apologies if this is a trodden path, but has anyone fitted the MLP slave to a 993 or 964? I read one post that claimed it's seals gave up after 2 years, but that was just one post. I'm looking to get one fitted in a few weeks. Thanks
Its one of the 3 best mods you can do to a 993.
You have to swap over the seals from the original.
Thanks. I heard that you have to use the original bellows (and spring?), but didn't realise that you need to reuse the seals. Are these usually serviceable given they are over 30 years old? I don't recall seeing new seals available separately as a service item.
You dont need to change any seals, you do need to swap over the bleed valve, spring & spring plate and the boot unless you get it from us as we supply a new boot.
